Other Parts Discussed in Thread: SN65HVD257, SN65HVD1040, SN65HVD255, SN65HVDA1040A, SN65HVD256
Hello, all
Now we are considering to use SN65HVD257, then would like to know the detail on the maximum signaling rates on this device.
When referring the datasheet of SN65HVD1040, this rate is defined as 250kbps when the bus length is 250m.
However, on the datasheet of SN65HVD257, same definition could not be found.
We assume that the maximum signaling rates itself on SN65HVD257 is higher than SN65HVD1040. Then we need to clarify this rate.
Actually, we need more than 250kbps when the cable length is 300m.
We thank you in advance for your information.
