TMDS181 - Interfacing DP++ with TMDS181 output
Guru 19785 points
Other Parts Discussed in Thread: TMDS181
Hello Team,
We are looking for a device which could bridge HDMI2.0 to DP++. Can we AC couple the TMDS181 output  ?.
I believe typical TMDS output is open drain circuit, so generally could not be used with AC coupling.
Our considering setup is the following,
HDMI connector ---------> TMDS181 ---------> FPGA DP++ input
Kawai
  • Hi Kawai-san,
    DP++ is a feature of GPU(Source) it is not a feature of Display(Sink).
    TMDS181 is an HDMI2.0 retimer, if you want to convert HDMI2.0 to DP you need a bridge, we don't have such devices.
  • Hi Kawai-san,
    As Moises noted, the TMDS181 cannot convert HDMI protocol to DP protocol.  The TMDS181 can, however, drive an AC coupled output, as long as there a pullups to 3.3V installed as well.
    JMMN
  • Hello Moises-san and JMMN-san,
    Thank you for your reply. First I had a wrong setup, required an AC coupling cap.
    Referring JMMN-san's answer, I believe TMDS181 TMDS output circuit is open drain circuit, am I correct ?
    i.e. without the pull up resistor at TMDS181 outputs, normal voltage swing level may not be able to pass through the AC coupling caps. I am thinking that with the following setup, correct TMDS181 output swing can be received at FPGA side with DC level cut.
    x        pull up with resistor
    x        |
    HDMI connector ---------> TMDS181 --------> C --------> FPGA
    Kawai
  • Hi Kawai-san,
    This is right, you need pullup resistors where you depicted them in order to have HDMI AC coupled signals.
    However, if source is HDMI, your FPGA should have an HDMI receiver, not a DP receiver.
