Other Parts Discussed in Thread: SN65HVD1780, SN65HVD1780-Q1
Hi everyone,
We are looking to create a robust J1708 node that will be used in automobiles. We had some questions regarding the loading configuration of a J1708 node, shown here:
1.) Consider the +5V as the output of our buck converter. If the Serial Data Bus line going to A is at a higher voltage, say 6V or shorted to battery (12V), would we need to protect our 5V supply from reverse current? Does this answer depend on whether driver/receiver are enabled/disabled?
2.) Ultra-low power is a necessity for us. We would like to put the chip in a standby mode with uA current draw, does this loading configuration allow that?
Thank you,
Tony
