Part Number: SN65HVD233
PARTNUMBER: SN65HVD233QDRQ1
Hello!
I attach the test report file that test same pcb again and additional pcb test.
Actually, Electronic circuit's has lot's of problem. I understant there is many kinds of reason, include my fault.
I just want to know why CAN communication error is appered.
So, Please check the SN65HVD233QDRQ1, history and simular case.
One month ago, I had experience fault situation. ( CAN Baud is 250kbps. Wire Distance about 1m. )
At that time, I just thought soldering fault because of quantity is 12 piece of pcb. ( SMT. Mouning is manual, Heating is Machine( small size ). )
Also, I had been reviewed my circuit design, MCU fault and so on.
And then, in my case, I confirmed that CAN Driver IC is Fault. Reason is
- It removed the fault with re-soldering a new IC.
- I checked MCU and Firmware with other CAN Driver Module using jumper wire. ( It removed the fault with only change CAN Driver Module )
And, I was to treat re-soldering myself, manual soldering, new IC. Something was pass, something was fault still.
One month later, Now.
I made new 30 piece of PCB.
Same situation is appeared.
Please check the situation and reply.
Thank you.
Below is a report to SN65HVD233QDRQ1.
IC Fault Revie
CAN Driver IC Fault Review
Part Name : SN65HVD233QDRQ1
Test Date : 30, Nov, 2017
CAN communication test for the IC (SN65HVD233QDRQ1)
At this time. --------------------------------------------------------------------------------
- Pass is 14 PCB.
- Fault is 1 PCB.
I want to know why it is changing.
Test Date : 29, Nov, 2017
1. When CAN communication error : I was resolved fault, connecting to other can module with jumper wire.
2. I was try to rework a new IC : even hand-soldering, Fault was remained frequently.
- Pass is 8 PCB.
- Fault is 7 PCB.
-> Fault rate is about 24 ~ 45%
- Pass is 4 PCB.
- Fault is 3 PCB.
- Pass is 3 PCB.
*** I don’t know why it was change.
The reason is other parts is all ok.
Designed Ciruit : SN65HVD233QDRQ1
Additional PCBs Test
ANOTHER 6PCBS tEST
Another 6PCBs : SN65HVD233QDRQ1
- Pass is 5 PCB.
- Fault is 1 PCB.
- Pass is 5 PCB.
- Fault is 1 PCB.
This another 6PCBs Test result is not changed.
At here, important is IC fault appears in my case.
I had experience same situation about one month ago. ( I do careful the ESD damage when testing. )
This second time appears IC fault again.
I want to know reason. My fault or IC fault ?20171129_IC_Fault_Review.pptx
