Part Number: DP83867IS
Team,
Could you please help with the below question:
we use the DP83867IS in SGMII mode, combined with 10mbit line rate.
In accordance to the datasheet, the 10M_SGMII_RATE_ADAPT bit in the 10M_SGMII_CFG register is set to '0' for this mode.
What is the effect if we leave 10M_SGMII_RATE_ADAPT set '0' on phy operation at 100mbit and 1000mbit line rate?
I have seen the below existing posts that are related to this but seems to discuss about when the 10M_SGMII_RATE_ADAPT is set to '1':
https://e2e.ti.com/support/interface/ethernet/f/903/p/633587/2342018?tisearch=e2e-quicksearch&keymatch=DP83867IS%2010M_SGMII_RATE_ADAPT#2342018
https://e2e.ti.com/support/interface/ethernet/f/903/t/633969
Thanks in advance,
A,.
