Is DP83867E a current-mode or voltage-mode line driver?
If it is a voltage-mode driver, then the voltage reference must be GND. Right? Is it necessary to wire the voltage reference (GND) signal along with each line driver signal pair (TD_P and TD_M) between the PHY and magnetics like this:
TD_P_A TD_M_A GND TD_P_B TD_M_B GND TD_P_C TD_M_C GND TD_P_D TD_M_D GND
Thanks!
