Part Number: SN75DP130
I did the same as the PHY compliance test 3.3, pre-rmphasis level Delta test did not pass.
It was written to try boost, so try boost.
Is there any other way to do this if you haven't passed?
Dear David
CTS3.3 results will be sent.
The BOOST setting was tested at 01 (Dafault).
RBR and HBR were good, but were rejected in 6-9.5db, with Hbr2 's 3.5-6db.
Calculation is likely to enter the range that does not pass in the boost setting, but I tried to set actually, boost was still insufficient.
Do you have to set anything other than boost (can be set)?
Tetsuya
Dear David
I calculated the value of boost before actually doing the test, and the number somehow entered the specified value.
However, I want measures other than boost in case that the examination fails.
The trace between the dp130 and the connector is about 12mm (0.5 inch).(Common Mode Choke Coil and ESD suppressor on the way)
Tetsuya
Dear David
The re-test was performed by setting the boost.
The result was a good result.
Thank you for your advice.
Tetsuya
