Part Number: SN75DP130
Hi Team
We use DP130 on our system , But DP phy test always fail , Could you help on this issue? Please check my Attachment file , Thank you so muchDP130 test fail.docx
Hi Team
Kerr
Are you using link training or i2c to configure the DPCD register? The failure looks to be marginal, have you tried multiple boards and do they all behavior all the same?
If using i2c, have you tried to write to the BOOST bits to see if it helps?
David
Kerr
My understanding from local FAE is that DP compliance is now fully passing with DP130 at local test house, would you please confirm?
David
