Part Number: DP83849IF
Dear,
I designed to use DP83849IF as media converter (100BASE-TX to 100BASE-FX). I've read DP83849IF's datasheet and AN-1509, tidu510a application note.
There is no any MCU for My board as media converter because i wanted to work as Media Converter Without Interface to MCU or MPU and Software Programming
So I known that to make DP83849IF operate as media converter, I dediacated Port A is copper and port B is fiber.
I need below
1. Configuration Port setting for media converter ; your evaluation kit is not worked as media converter as i tested.
2. Dose DP83849IF is worked without any MCU or program really??
3. If no.2 question is not true, what can i do? Could you recommand another solution, please?
Best regards.
