Part Number: DS16EV5110A
Other Parts Discussed in Thread: TFP401A, TFP401, DS16EV5110,
Hi:
Can 5110A interface with TFP401A ,while 5110A as driver and TFP401A as receiver,DC couple interface with each other? thanks
Hi:
Hi Lin,
Outputs of DS16EV5110A are indeed open collector outputs - as noted in the data sheet. You can check this - first disconnect your HDMI cable - by externally pulling up - through a 50-ohm resistor - to 3.3V supply and then put your scope probe to monitor output being raised to 3.3V. However I cannot say where 1.2V supply is coming from.
Regards,,,nasser
