Other Parts Discussed in Thread: LMP7711
Hello I have the strange problem reported here https://e2e.ti.com/support/interface/f/138/p/542596/1981841?tisearch=e2e-sitesearch
Did anyone solve it or is it a bug? Thank you.
Did you try the suggestions in the other thread you linked, such as maximizing ICP1 to compensate for any leakage current due to VCXO input resistance and/or loop filter path, or maximizing the LOCK_CTRL value to relax the phase lock threshold? It the VCXO input resistance is low enough to contribute enough leakage to introduce a phase error at the PLL1 PFD inputs, you may need to add an op-amp with high input impedance (like LMP7711) to buffer between the loop filter voltage to and VCXO input.
Alan
