Part Number: TUSB542
Other Parts Discussed in Thread: TPS25810,
I'm using the TUSB542 re-driver in conjunction with a TPS25810 controller for a USB-C to USB3-B converter with power injection.
We purchased a test platform: https://www.totalphase.com/products/advanced-cable-tester-l2/ (which is a cable tester platform) in order to validate the design and generate an eye-pattern @ 5Gbps.
We're unable to perform the eye-pattern test as the TUSB542 seems to stay in disconnect mode and doesn't go in what we believe should be U0 mode. Can you elaborate how the device functional modes are processed? The spec-sheet doesn't provide detailed information.
Thanks!
