Part Number: DS125DF111
Hello.
We use DS125DF111 got return loss fail issue.
The current set output voltage is 600mV. De-emphasis setting 0~-12dB is all Fail. The output voltage should be set above 1000mV will be Pass.
But if the output voltage is over 700mV, the eye diagram will be Fail. Can you provide your suggestion to solve this problem. Thank you Help~
