Part Number: TPS65987D
Hi Team,
In order to use the SPI-Flash Less Application,
Are there any time restriction of I2C Patching timing from Host MCU to TPS65987D after the TPS65987D is enabled from the view point of USB Type-C/PD specifications under the other side device (already active) is connected through USB Type-C?
For example, the I2C Patching from Host MCU to the TPS65987D after the TPS65987D is enabled have to be done within ?? sec.
Thank you.
Koshi Ninomiya
