Part Number: THS8200
About THS8200, I have some questions as follows.
1. Is there any requirement for time sequence of power on and off?
2. For R[9:0],G[9:0],B[9:0], I only used 8 bits, should the lowest two bits be connected to ground directly or through a resistor of kOhm?
3. For 20bit or 10bit mode, should unused Pin be connected to ground directly or through a resistor of kOhm?
4. Should VS_IN,HS_IN,FID be floated or connected to ground through a resistor of kOhm when using internal sync?
