DP83822IF: DP83822IF's link(2)
Part Number: DP83822IF
. It is set to 100BASE-FX, but the link is established 201.5ms after reset release.
In this case, the measured link up time is 201.5ms, so can you say that the link up time does not exceed MAX300ms by looking at the margin from PHY's logic of several internal processes?
If MAX300ms is not enough, can you say that the link up time will not exceed MAX400ms?
