Part Number: DS90UB913A-Q1
Dear Support Team;
I would like to confirm the following sentence.
I think the following timing.
Is it correct?
Masaaki Sugiyama
Dear Support Team;
Is it correct?
Masaaki Sugiyama
Dear Support Team;
I made a mistake.
"10-bits of DATA + 2 SYNC bits for an input PCLK range of 50 MHz to 100 MHz in the 10-bitmode.
Note:HS/VS restricted to no more than one transition per 10 PCLK cycles."
Masaaki Sugiyama
Hello Masaaki,
I still do not understand your question. Can you please restate it a little bit more clearly?
Casey
Dear Casey-san
Sorry for not enough my information.
I made explanation file and upload.
Could you confirm it?
B.R
Masaaki Sugiyama
Hello Masaaki,
The datasheet is saying that the HS and VS signals can not have a pulse with less than 10 PCLK cycles. What goes into the 913A is the same as what comes out of the 914A. It does not change the HS/VS width.
Casey
