Part Number: DP83822IF
I read this thread: https://e2e.ti.com/support/interface/f/138/t/745280?tisearch=e2e-sitesearch&keymatch=DP83822IF. What seems to be missing is a test mode where it outputs all 1's as a Manchester encoded packet repeatably. The compliance test software from Tek that we use triggers off of TP_IDL to repeatably capture the data. Using register 0x0027 with the test pattern of 0011 - Repetitive 1 puts out a pure tone sine wave, not Manchester encoded. Thus, forcing a TP_IDLE forcing the test pattern TP_IDLE_00 at the end of the test pattern 0011 would test the pure tone and not the Manchester encoded data. Is there a way to force an all one's Manchester encoded packet as required per 802.3-2012 Section 1 Clause 14.3.1.2.1?
