Can you please try setting register 0x16 to enable either digital or PCS loopback?
=> After to add the suggestion of Ti E2E website suggestion as below test result for 10Base-T
There are many items of 10Base-T cannot measurement since Ti Ethernet PHY DP83825I of 10Base-T Standard Test script cannot work as below.
0x16 = 0x710f
1213-2019-Ti-DP83825i_PHY_IEEE802.3_Compliance-test-10Base-T_issue.pdf
100Base-TX-MDI (Pair A) |
Pass |
100Base-TX-MDIX (Pair B) |
Pass |
10Base-T |
Link Pulse |
Pass *1 |
TP_IDL With TPM |
Fail *1 |
TP_IDL Without TPM |
Pass *2 |
MAU, Internal |
Fail *1 |
Jitter With TPM |
Fail *1 |
Jitter Without TPM |
Fail *1 |
Differential Voltage |
Fail *1 |
Harmonic Content |
Fail *1 |
Common-Mode Voltage |
Pass *2 |
Pass *1 |
Link pulse Script file. |
*F1: |
The Issue of Ti DP83825I Ethernet PHY cannot output correct pattern of IEEE 802.3 compliance test waveform of 10Base-T Standard Test Script. |
Pass *2 |
10Base-T Standard script for PHY Registers 0x16 =>0X710f |
