Part Number: DP83867IR
The customer applied EFT test on Ehternet cable by using coupling adopter. After applied noise, communication error occurs. Configuration is attached #1.
They added HUB between controller and display for connecting PC. This configuration is attached #2.
PC send ping command for display and controller. Reply comes from display but not from controller. When cable is disconnect then re-connect, communication was recovered. RESET command is also worked for recovery. I think DP83867 becomes error condition by EFT noise.
[Question]
1. Do we have a way to know DP83867 becomes false condition? If we can know communication is false, they may find a way for recovery.
Toshihiro Watanabe
