Part Number: DS90UB954-Q1
Is there a way to program the IC such that its drive strength can be modified when used in CSI-2 mode?
Thank you,
Andreea
Thank you,
Andreea
Hello Andreea,
What do you mean by driver strength? Do you mean the CSI-2 output VOD? Or something else?
Casey
Hello Andreea,
The CSI-2 output is calibrated carefully to meet the MIPI DPHY voltage and timing specifications for TX under all datasheet conditions so it is not recommended to change anything related to the signaling levels otherwise the DPHY compliance can not be guaranteed.
Casey
