Other Parts Discussed in Thread: TLIN10283-Q1
Hi team,
1. Wake up sequence
Could you share me wave forms of the below signals during mode transition for TLIN10283-Q1?
Mode1 : Power off --> Standby
Mode2 : Sleep --> Standby
SIgnals : Vcc, nRST, Vsup, LIN
2. Wake up procedure from Sleep
If you receive wake signal on LIN bus while in sleep mode, the device should be wake up to Standby state, correct?
In order to make the device to Normal state, do you need to pull EN pin High in Standby state?
In this case, do you normally pull EN to Vcc? or do you pull up control EN pin by MCU which is powered by Vcc?
