Part Number: LMH1208
Other Parts Discussed in Thread: LMH1219
I am working on a 12G SDI interface in which I am combining LMH1219 and LMH1208 to relay the incoming SDI signal.
My question is regarding the pcb layout, in which I am using pins OUT+ and OUT- from LMH1219 to connect to LMH1208 pins IN0+ and IN0-, respectively. Due to the position of these pins, unless I route them separately, I have to inevitably overlap them in order to connect both IC's. Since this is a layout sensitive design, how is the best way to route such signals?? My initial thought was to partially route one of the signals on the bottom layer using vias but I am not sure how it would affect the impedance.
Thanks in advance,
Murilo
