Other Parts Discussed in Thread: TFP401, THS8200, THS8135
Will TI be able to provide me with a HDMI to component video converter circuitry ?
Dear,
TI does not have a single chip solution that could accompliah what you are trying to do.
However, there may be a multi-chip solution that you could use. The TFP401, DVI Receiver could extract the video portions of the HDMI signal and will convert them to a parallel 24 bit RGB digital signal. You then could connect a video DAC that would convert this 24-bit RGB to analog component video. You should look at the THS8200 or the THS8135 for your video DAC. There may be other solutions on the video DAC side as well - I would suggest posting a question in the Video Converter's Forum for more suggestions on the DAC portion of the solution.
DHarmon
I am thinking of following choices:
Now do tell me whether each of the aforesaid conversion is feasible or not.
kndly do also tell me about the embedded sync on green of DAC.(AGY)
Moreover TFP401 gives out 24-BIt RGB even and odd pixels.Then how to connect this with 10 bits of three channel DAC.
what is this even and odd pixels??? what should i do with them??
Please help me out.
email id: saptarshi.smit@gmail.com
Saptarshi
