Part Number: DS90LV011A
Hi Team,
customer is wondering if we have mini-LVDS to LVDS solution?
Please kindly advise if we have any, the application is TV.
Thanks!
Patty
Hi Team,
Thanks!
Patty
Hi Patty,
Can you share the specs for their mini-LVDS driver?
I.K.
Hi I.K.
- support 1280x720_60Hz / 1366x768_60 Hz / 1920x1080 _60Hz
- support two data format input: 6bit Hi Hi-FRC & 8bit
- support 6pair & 3pair (Maximum 1port 6pair or 2port 3pair)
thanks!
Patty
Hi Patty,
Sorry I meant please share the electrical specifications.
I.K.
Hi I.K.
per communicated with customer, they need 4 channel and the signaling rate is 250mbps. however, using our web tool to filter out, it seems like we don't have mini-LVDS to LVDS solution.
The application is TV and the main board is mini-LVDS and need to connect to the display which is LVDS. Do we have any solution that can meet customer needs?
Thanks!
Patty
Hi Patty,
We don't have any device specified for mini-LVDS. However, it may be possible connect it directly to an LVDS receiver without any need for converting. I'm not familiar with mini-LVDS so I need to know the electrical specifications of their driver. Please share the electrical specifications of their mini-LVDS driver (you can take a look at the electrical characteristics table of the DS90LV011A as an example).
I.K.
Hi I.K.
Please refer to attached from customer, mini LVDS spec, this mini-LVDS input needs to be converted to LVDS output.
Thanks!
Patty p18.pdf
Hi Patty,
These specs (VID and common mode voltage) are already compatible with LVDS. It does not need any conversion.
I.K.
