Part Number: DS90UB948-Q1
Hi team,
I am investigating the failure mode analysis of the case where D0- pin open failure.
I cut D0- wire at UB948 output, so termination resistor at Timing controller input side is still connected between positive and negative LVDS inputs of TCON.
Could you advise how is the TCON input signal looks like and what do you expect data to become?
Because I set LVDS bit mapping to JEIDA mode, D0- output is G - R7 - R6 - R5 - R4 - R3 - R2.
I think if D0- is disconnected, LVDS line is pulled High and all data in D0 channel becomes 1.
Is my understanding correct?
regards,
