Part Number: DP83867IR
We are working on the DP83867 Ethernet PHY chip loopback testing.
As per the datasheet it was mentioned that LOOPCR register need to be set to value 0xE720 for Lopback to work.
After setting this register we need to immediately perform software restart using 0x00FE register 14 bit.
By default this register should hold the value 0xE721.
But when we read this register we are getting value as 2 and when we set its value to 0XE720, even after software
restart we are not able to set any other register for Loopback testing. All register will remain 0 only.
As per the comment given in the below E2E forum discussion page, Loopback test works only after setting the LOOPCR
register. Please check the link below:
https://e2e.ti.com/support/interface/f/138/t/684210
Waiting for your reply,
Vipul
