Other Parts Discussed in Thread: THVD8000
Dear Sir,
Is there any transreceiver or Analog Front End (AFE) device for designing Signaling line control circuit for digital fire/smoke sensors?
The requirement is to design a two wire Loop card which uses different voltage ranges called voltage pulse code modulation (PCM) to send 1 and 0 to sensors connected on the loop line. Devices/fire sensor consume current responding with 1 and 0. The Loop card also provides power to devices on two wire bus and need to drive either 250 or 500 such sensors.
Pls. suggest.
