Part Number: TDP158
Dear colleagues,
I have exactly the same problem as described in this E2E post:
Unfortunately the post was interrupted and does not show the solution. Can anybody tell me the reason what caused this issue ?
Best regards
STG
Part Number: TDP158
Dear colleagues,
Best regards
STG
Hi David,
Since I do not want to share things in public, I have sent you a mail...
Best regards
STG
Hi David,
I just saw, that I cannot respond to the mail which I got from TI <noreply@mail.e2e.ti.com>
Is there a way to send you a private mail. I do not want to share things in public...
Best regards
STG
STG
I sent you a direct email, would you please check? We can communicate through direct email.
David
Hello David,
I think I have found the problem. It has probably nothing to do with the TDP158, and the corresponding circuit.
It looks like the display is turning off the termination periodically when the input timing does not exactly meet the expected input timing requested by the EDID.
So it looks like that the display is hanging in the following loop:
1. Turn on termination
2. Detects a input timing
3. Checks the input timing
4. Since the input timing is wrong, it turns off the termination
5. Wait ~1 seconds, then goto state 1.
I'm now going to change the timing. Will let you know what happens....
STG
