Part Number: TPS65987D
Hello Team,
We are using TPS65987D in our solution as Android Accessory. But when we are connecting to mobile, we are not able to detect the device correctly.
After debugging using TI Application Customization tool, we observed it is detecting the mobile connected but it stuck in USB Type C state
COMMON_STATE_ATTACHWAIT_SRC. As per specification, after stable CC line voltage for debounce time and VBUS detection it should enter COMMON_STATE_ATTACH_SRC state.
But we are observing CC line gets stabilized but stuck in the same COMMON_STATE_ATTACHWAIT_SRC state. Attaching the debug logs for the reference. The same project file when we use with EVM kit it is working fine.
Port 1 Module 31 0x1ff = UNKNOWN
Port 0 PD 0x1 = PEState_CableTypeDetect
Port 0 INT 0x3 = PLUG_INSERT_OR_REMOVAL
Port 0 Type-C 0x67 = COMMON_STATE_UNATTACHED_SRC
Port 0 VBUS 0xcc = VBUSState_MON_HILO
Port 0 VBUS 0x91 = VBUSState_MON_LO
Port 0 Type-C 0x64 = COMMON_STATE_ATTACHWAIT_SRC
Port 1 Module 31 0x17f = UNKNOWN
Port 1 Module 31 0x101 = UNKNOWN
Can you please share your inputs / comments on the issue?
Thanks & Regards,
Amol M Shrotri
