Part Number: TFP410
Hi TI Team,
We are using TFP410PAP IC for DVI output application. We are able to make it work in 24 bit mode for 1080-60fps.
So now can we use 16bit data without changing any configuration of IC. If not, what and all should be taken care.?
We found in datasheet that unused data lines should be pulled low /high, but unfortunately we didn't provide this option, since we considered 24 bit mode initially.
So is it must to pull-up or pull down the unused data lines. Please provide your valuable inputs.
Vyshnav Krishnan
