Part Number: DP83867IS
Consider a case where one or more of the A,B,C,D lines are connected to the magnetics, but have their polarity reversed.
For example, consider a case where the B and D lines pins between these two PHYs have polarity switched.
Will the DP83867IS automatically detect the polarity and correct? (Other E2E posts seems to suggest yes) If not, the board will need to be re-designed (vias added)
Are there any specific register settings that need to be set for this?
