Could you provide the full datasheet, because for existing datasheet they didnt have figures 11,12,13 etc but mentioned in Electrical Characteristics as see in figure 11,12 ,13 etc but figures are not there.
Could you please provide the full datasheet for ISO3086 with all Figures .
Thank you for pointing the numbering difference out. The datasheet online is the full datasheet; however, the numbering didn't populate correctly. Please see the below bullets showing how to align the figures.
I hope this helps.
Andrew
1)What is Positive-going input threshold voltage VIT+ ?? and Negative going input threshold voltage VIT- ?? |
2)and what is the required values/Acceptable range as per EIA RS485 Standard for positive going input threshold and negative going input threshold voltage for RS485 IC??
3)Driver differential output voltage magnitude
4)what is the acceptable value for Common mode output voltage acceptable values for Standard RS485??
5)Input current range for D,DE for standard RS485 IC?
6)What is input hysteresis of receiver in RS485 ? and acceptable value range for Standard RS485 as per EIA Standard??
Andrew
