Other Parts Discussed in Thread: ISO7741,
Hi
The voltage difference between VCC1 and bus voltage is 800V,
VCC2 and bus voltage is the same reference ground,
Can ISO7741 be supported?
Thanks!
Hi
Thanks!
Hi Neal,
Thanks for reaching out.
From what I understand, VCC2/GND2 share the same reference GND as the bus reference GND while VCC1/GND1 is on a different reference GND and the voltage difference between the two GNDs can be 800V continuously for the product's lifetime. Yes, this isolation voltage is supported by ISO7741-Q1 in DW package.
The voltage difference between any pin on Side1 (VCC1 side) and any pin on Side2 (VCC2 side) can be upto 1500Vrms or 2121VDC continuously for device's lifetime for ISO7741-Q1 in DW package. This spec is defined in Section 7.6 (Insulation Specifications) of ISO7741-Q1 datasheet. Thanks.
Koteshwar Rao
Hi
What is the difference between the two voltage standards?What standard do I mainly refer to when choosing IC,as below,thanks!
Hi Neal,
SSOP (DBQ) only has a creepage of 3.7mm which is not sufficient to support 800V of isolation working voltage. The device ISO7741 is capable but the SSOP package is smaller size and is meant for application where working voltage is <566 VDC. Hence, DW package with 8mm creepage should be a suitable device for customer application.
VIOWM and VIORM refer to the same levels while VIOWM is expressed in RMS and VIORM is in peak. This is similar to RMS and Peak voltages of a typical sinusoidal AC signal. If a system has fixed DC voltage and there is no switching involved like in BMS applications, VIORM should be referred. If a system has fixed DC bus but the voltage across the isolator is switching like in motor drives and solar inverters, then VIOWM should be referred. Thanks.
Koteshwar Rao
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
