Other Parts Discussed in Thread: TPS62110-EP, TPS62110-Q1
I want to replace TPS62110HPWP with a cheaper version (industrial or automotive) - is there a DC/DC converter which is pin compatible with this item?
Thank you,
Thank you,
Hi Kyle,
Thank you for your quick response,
I'm looking for a replacement which doesn't have to be with the exact same functionality and parameters, but it must be pin compatible.
My input voltage is about 4.2V and output voltage is 3.3V, output current can range from 1A to 2A.
Is there a matching part you can think of?
Thank you,
