Hi, team
What's the maximum delay difference time between channels? Customer require <3ns, can we meet this requirement?
Which means give the inputs signal at same time and the time difference between output signals.
Hi, team
Hi Mona,
Generally our parts don't have a skew time defined. However, you can expect <1 ns delay between channels in the same device so this should be fine for your application.
Hi Albert, can I also assume CAVC8T245QRHLRQ1 has <1ns delay? what's the difference between CAV and CAX?
Hello
The AXC logic family was designed as a direct replacement to the AVC family, with many improvements over the older logic -- specifically targeting glitches during the power-up and power-down ramp times. Neither family has skew specified or characterized, so we can't guarantee anything regarding skew numbers.
