Other Parts Discussed in Thread: SN74AXC4T245
We are using TXU0104PWR for 3.3V to 1.2V translation.
Waveform attached shows Input (Yellow waveform) and Output (Green Waveform) of the translator.
Output green waveform don't swing from 0V to 1.2V but swing from 0.35V to 1.2V. It is above VIH of the input device.
When we connected 3.3V 100Mhz clock to input of the translator, we got flat 0V line at the output of the translator.
When we connected 3.3V 32Khz clock to the input of the translator, we got perfect 0 to 1.2V 32Khz clock at the output of the translator.
Can someone confirm if we can use this translator for 25Mhz and 100Mhz data/clock signal?
Also, please confirm why we are seeing low swing at 0.35V for 25Mhz signal instead of 0V?
