Hello Team,
Currently my customer has some design guide and SN74LVC573A working mechanism questions, could you please help with it? Thanks!
Q1: What's the recommended connection of the signal pins, floating, pull up or pull down? Can you fill in the table as below:
| Pin | Used | Un-used |
| LE | ||
OE |
| D_IN | Pull down to GND | |
| Q_output | Floating is ok |
Q2: Is there timing sequencing requirement between the LE/D_IN/OE/VCC, I couldn't find it in the D/S. What may happen when the VCC comes after the LE/D_IN/OE?
Thanks!
