Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LSF0102-Q1: LSF0102-Q1 sch review
Part Number: LSF0102-Q1
Hi expert,
Could you pls help review below sch? thanks.
And why do we need to choose a pull-up resistor like this? If I choose to high, what will be the impact? thanks.
  • The datasheet shows what resistors are needed to get a specific pull-up current.
    But these current values are just some examples. Depending on the signal frequency and the board's capacitance (about which you have not told us), the required current might be much smaller.
  • Hello Hangjie,
    It's hard to see with some text overlapping but as long as this pull-up is 200Ωk then it's fine.
    The resistor values determine how much current your driver will sink. The lower the value, the more current you will sink which allows higher signal frequencies to be used.
    Josh
