Other Parts Discussed in Thread: SN74LVC1G98, SN74LVC2G02, CD4043B, SN74LVC2G74-Q1
Is there a single channel small RS Latch out there? I just need one bit with no clock. Press one button, the output goes high, press the other button, the output goes low. 5 volt operation would be great. I could use a Dual NOR gate I suppose. Or even a D Flip Flop with Set and Reset inputs if I could find one with active high inputs. Anyway, if you were to build one, I would happily buy several hundred a year. If not, what is the most common work around? Thank you, Charlie
