I'm struggling with a SN74HC595 shift register. Output Qa turns on momentarily regardless of what it is commanded to do, when the OE (output enable) is pulled low. Am I interpreting this correctly that, regardless of anything else, Qa will momentarily go high when OE is pulled to ground based on the timing diagram on page 7 of the spec sheet?
It shows all other outputs will stay low.
Thank you.
