TPLD1202: WD configuration issue
Part Number: TPLD1202
I had time to get my hands on the the WD configuration.
I can't get the WD to work as intended...
I have the following design:
The delay is used to block the watchdog for a duration after reset.
I have the following WD block configuration:
And the WD refresh simulation parameters are the following:
I am observing the following curve:
As you can see I am toggling the refresh input at a 10µs rate and I have configured the watchdog for 100 osc1/2 cycles so I would not expect the wd to trigger a fault, but it does.
Any ideas ?
Clément
