Part Number: CD4013B
Dears,
End customer's application is designed for gas meter. Issues happened, high current dissipation from CD4013B.
We found if we cut off end circuit, current still dissipation around 500uA-2mA from CD4013B.
Normally, Q15 is open, when load circuit short, R58's voltage will work more than 0.6v, this will drive Q15 work, and Pin6 Set a under high level voltage, then Qa pin will output high level voltage, it will drive Q13,Q14 work on opening status. it will cut off load circuit.
Questions: What condition will produce high current dissipation from CD4013B
