Other Parts Discussed in Thread: SN74LVC1G17
Is there any possibility that penetration current is flown when the input pin is opened?
Kuramochi
Kuramochi
Hey Kuramochi,
I'm not sure if I follow the question exactly, but if the input is left open then you will have a floating node and this can cause an increase in supply current.
Dylan-san,
Thank you for your help.
My customer says that the competitor device flows penetrating current when input pins are opened.
Does it mean that SN74AHCT1G125 is taken measures for penetrating current?
Kuramochi
I guess the proper term is "shoot-through current".
TI devices behave in the same way: [FAQ] How does a slow or floating input affect a CMOS device?
The simplest way to avoid a floating voltage at the input would be to add a weak pull-down or pull-up resistor.
Clemens-san,
Is the device damaged by this shoot-through current?
Kuramohi
If the voltage is near the switching threshold, oscillations can happen. Those are more dangerous, and possibly damaging.
Devices with Schmitt-trigger inputs (e.g., SN74LVC1G17) will not be damaged by floating inputs. They have no oscillations, but they still have shoot-through currents.
Hi Clemens-san,
Does the shoot-through occur when the device is disabled (/OE=H)?
Kuramochi
The OE pin disables the output. The input always stays active while the device is powered.
