Part Number: TMS570LS1224
Other Parts Discussed in Thread: HALCOGEN
Hello Team,
I have a client who is asking about the configurations of the following pins: N2HET PINS / MIBSPI PINS / CAN1TX PINS to GPIO.
Below is his full transcript:
How to use N2HET PINS / MIBSPI PINS / CAN1TX PINS as GPIO and output a logic 'high'.
Actually some N2HET pins i want to use pins as N2HET functionality to output a PWM and some N2HET only to use as GPIO ( Ouput a logic 'HIGH' ). I wanted to know to configure the HET pins as GPIO ( Input/ output) in CCS. What I need to configure in Halcogen ?
N2HET1[29] as' Input pin' ( GIO)
N2HET[1] / N2HET2[8] as' Input pin' ( GIO)
N2HET1[27] as' Input pin' ( GIO)
N2HET1[11] as 'output pin' ( GIO)
N2HET2[0] as' output pin' ( GIO)
N2HET2[4] as' Input pin' ( GIO)
Also how to make the particular pin say N2HET2[4] output a ' Logic High'.
Is it possible to set those pins to GPIO? I saw a post that it's possible for CAT Rx/Tx pin, but how?
Thank you for your guidance and continued support.
Archie A.
