how to suppress all warnings with pragmas
I'm trying to use pragmas to disable all warnings for a particular section of code.  I'm using ti-cgt-arm_20.2.5.LTS.
I also want to suppress specific warnings (which I know there are many threads on) but it would be useful to have a reference of warning and error numbers.  Is this published anywhere?
#pragma diag_push
#pragma diag_suppress [what goes here?]
// code block
#pragma diag_pop
  • The typical method ... Build that block of code with no #pragmas.  Use the build option --display_error_number.  This causes each diagnostic to include an ID number, similar to ...
    "file.c", line 7: warning #112-D: statement is unreachable
    Suppose your block of code gets that diagnostic, and you want to suppress it.  This #pragma is one way to suppress it ...
    #pragma diag_suppress 112
    Notice how the number 112 comes from the diagnostic.  For all the details, please search the TI ARM compiler manual for the sub-chapter titled Understanding Diagnostic Messages.
    Thanks and regards,
    -George
  • This isn't really the question I asked.  I want to know how to suppress all warnings for a given code block, not a specific one.  The comment about also wanting specific warning suppression was just to ask if there's a published list of them somewhere.
  • The entry EXT_EP-9948 has already been filed to request that a list of all the possible diagnostics be made available.  Unfortunately, it has not been completed.  I will add your request to it.  Note this request will be logged in a part of the entry that is not publicly available, so you will not see any change in the public view of the entry.
    Thanks and regards,
    -George
  • Thank you.  Any idea about original question?
  • Unfortunately, there is no #pragma, or anything similar, which suppresses all warnings.  The closest possible solution is the command line option --no_warnings.  If your code is organized as a CCS project, you could use File Specific Options to apply --no_warnings to just one file.
    Thanks and regards,
    -George
