Part Number: RM57L843
My customer implement SRAM self test using Diagnostic Library 2.4.0.
Check RAM ECC:
boolean retVal;
SL_SelfTest_Result result;
retVal = SL_SelfTest_SRAM(SRAM_ECC_ERROR_FORCING_1BIT, TRUE, &result);
if(retVal == false){while(1);}
if(result != ST_PASS)
/* Test fail */
while(1);
retVal = SL_SelfTest_SRAM(SRAM_ECC_ERROR_FORCING_2BIT, TRUE, &result);
/* Test fail */
while(1);
Check Flash ECC:
boolean retVal;
/* Flash test needs to be run from a RAM location. Copy flash test to RAM */
uint32 i;
uint32 size=(uint32)&ulHighHandlerSize;
for(i=0;i<size;i++)
((char *)&ulHighHandlerStartAddr)[i] =((char *)&ulHighHandlerLoadStart)[i];
retVal = SL_SelfTest_Flash(FLASH_ECC_TEST_MODE_1BIT, TRUE, &result);
/* Test fail */
while(1);
retVal = SL_SelfTest_Flash(FLASH_ECC_TEST_MODE_2BIT, TRUE, &result);
/* Test fail */
while(1);
But all tests failed and stuck in the while loop.
/* Test fail */
while(1);
The code seems correct. What is missing here?
Thanks and regards,
Koichiro Tashiro
