Part Number: AM2432
Hi Expert,
Our product will use RTI watchdog triggering warm reset. First I tested the watchdog example in SDK 08.02.00.12, but I found warm reset doesn't work correctly.
I set syscfg as below, and called watchdog_reset_mode_main() from main(). I can see only "Prints will be stopped after reset " is repeated without stop in CCS console.
Could you clarify the reason why the SDK example is not working?
fyi, the interrupt mode example of the watchdog is working well.
Moonil
