Part Number: TMS570LC4357
TRM §16.1.1 says:
Group3 (high severity) channels with no interrupt generation and predefined ERROR pin behavior. These channels have no interrupt response as they are reserved for CPU based diagnostics that generate aborts directly to the CPU.
Is this true for all group 3 errors? The response for the related question indicates only error pin and status register error flags will be set. (Answer from Charles Tsai)
TRM §2.3.2.5 Conditions That Generate Aborts also lists "• Parity / ECC / Time-out Error on a valid access" as a source of abort. Does this occur in paralel with the effects described in TRM §12.2.1 (EPC chapter) Uncorrectable Fault Operation?
