Part Number: RM57L843
1. The ESM interrupt "ESM_G1ERR_EPC_SERR" was not triggered after we use "SL_SelfTest_Flash" with passing test type "FLASH_ECC_TEST_MODE_1BIT" to insert EPC 1-Bit ECC error.
2. The ESM interrupt "ESM_G2ERR_EPC_UNCORR" was not triggered after we use "SL_SelfTest_Flash" with passing test type "FLASH_ECC_TEST_MODE_2BIT" to insert EPC ECC uncorrectable error.
Can you help please check if anything wrong in your diagnostic library code as below?
Have you tested all the APIs and verified their usability on RM57L843? If yes, can you help provide the test report for our reference. Thanks so much
